ghohouston
So last weekend I finished my e fuel install, sd bowl, sd lines, hpop resovoir, etc.. with a riff raff frx. On the initial test drive, the truck would run good, until you got into it hard. It would start "skipping" or missing. I mean BAD, bad enough it chirps the tires when this happens. It would do it in any gear. My initial thought was air in the fuel system, and me never working on a manual transmission truck, made me think air in the system even more. Fast forward to a week later, truck still doing the same thing. I noticed if I take it easy in first, and second for a bit, it will not skip if I get into the throttle hard, but will do it again if i let the truck sit for a few hours. I've probably put 100 miles on the truck since the install, so the air in the fuel idea isn't looking promising anymore. Any insight? Is this normal for a manual trans truck to do with air in the fuel system? I've worked on hundreds of powerstrokes, but this is the only manua, and the only issue like this I've dealt with.
