Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 05-01-2017, 01:35 PM
JO9816 JO9816 is offline
Private
Member's Gallery
Default 160/30 injectors real world reviews
Hey everybody,
I've been looking hard at aftermarket injectors and turbos, and have pretty much decided on a set of 160/30 injectors. Mainly because I'm on a budget and I don't have the time or money to put into a ton of supporting mods at the moment. I'm pretty set on the drop in ball bearing turbo from Dieselsite for my truck since it is an early 99 and I don't have a lot of options other than a t4 mount which exceeds my budget. What I'm mainly looking for is people that are currently running or have ran some 160/30 injectors with no supporting mods or a lot of supporting mods (hpop, turbo, fuel system upgrades ect.) Did you like the setup? Did it meet, not meet, or exceed the kind of power you were expecting? My truck is currently a daily driver, and I tow a boat quite often in the summer, but the boat only weighs about 5k so not much of a load at all. I only want to do injectors once, and I don't want to be disappointed in the power from 160/30. Any help/advice is greatly appreciated!
__________________
Early 99 7.3 with the basics: PHP tuned, 4 inch exhaust, leveled on 305/70/16, 2002 cupholder (best upgrade I've done ), 05 grille, 6637
To do list....MORE POWA
  #2
Old 05-02-2017, 09:34 AM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
The question really is what do you want? Going to single shots from splits is a nice upgrade and it a better use of the oil. Just bolting those in with decent tuning you should get you 350-375 on a max effort file. Compared to stock, it wont set the world on fire, but its a decent kick in the behind.
I wouldn't spend a lot of money on other upgrades for those injectors until parts die. Then upgrade the pump, turbo, etc.
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #3
Old 05-02-2017, 09:48 AM
Private
Member's Gallery
Default
I want to be right at or a little above 400 and from my understanding, I should be able to achieve that if I do all of the supporting mods. Do you think I'd be better off getting some small hybrids like a 238/80 and tuning them down until I get all of the supporting mods? I really don't want to have to stud it if I can help it.
__________________
  #4
Old 05-02-2017, 12:09 PM
Tim @ P.I.S. Tim @ P.I.S. is offline
Lieutenant
Member's Gallery
Default
200/80's would be perfect for what you want since you are upgrading the turbo.
And with that design you could easily hold 3k icp all day with the stock hpop.
  #5
Old 05-02-2017, 03:28 PM
Private
Member's Gallery
Default
I think I would enjoy the 200/80 a lot more, but I want to maintain as much reliability as I have now. I also don't want to have to put a ton of supporting mods in it like a whole new fuel system, studs, rods, springs. I like the idea of saving money on an hpop, but if I have to put it towards a ton of supporting mods, I'm not saving much.
__________________
  #6
Old 05-02-2017, 03:57 PM
The Brad's Avatar
The Brad The Brad is offline
Sergeant
Member's Gallery
Default
The way I see it, you have 2 options: 160/xx, or bigger, but detuned until/in case you want more power. The only question is, will you have the funds and desire to chase more power?
__________________
2000 CCSB 4x4, 6in lift, 315/75-16, Joe Shmoe built 4r100, 3.73, 200/80s, CSD T4 SXE364.5/74/.91, Comp 910's shimmed, Smith Bros push rods, live tuned, Riffraff boots and plenum insterts, FRx, 6.0 Trans cooler.
  #7
Old 05-02-2017, 04:21 PM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
You won't need to do anything to the 200/80's they will run just fine on a totally stock truck. Supporting mods. will improve their performance even more, but they will be fine at stock.
Reliability wise, injectors from the guy that recommended them to you would be at least as reliable as the injectors that International put in there when they built the motor.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #8
Old 05-02-2017, 05:33 PM
CarportMechanic CarportMechanic is offline
Sergeant
Member's Gallery
Default
Agreed that PIS is a good quality injector builder.
Stay away from the 175/xx if you want to run your stock HPOP. They require more oil than stock injectors.
I wanted more fuel than the 160's but did not want to much more. 175's sounded good. I wish I had stepped up to a 200 or 238 hybrid.
Now that I have a good pump my rig runs great but I could not maintain over 2,200 PSI with a stock pump or even a modified pump.
__________________
2000 F-250 XCLB 6 Speed 190K, PIS 175/80's, ARP's, 910's, Irate Fuel, Hydra PHP tuned, 38R, MB HPOP, DIY Trac bars.
Wish list: Fluidampr,
  #9
Old 05-02-2017, 05:40 PM
The Brad's Avatar
Sergeant
Member's Gallery
Default
My 200/80s and original HPOP holds 3k at 42% duty cycle at 3.2ms. I did springs and push rods while I was in there, but I don't have studs.
__________________
  #10
Old 05-02-2017, 05:48 PM
Private
Member's Gallery
Default
With my php hydra cranked all the way to "extreme", I see about 2700-2800 at WOT, so I might need a new pump anyways unless the hybrids use a lot less oil. There's nothing wrong with the injectors now (knock on wood), so do you think it'd be best to put all the supporting mods on and then add the injectors?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
