Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #471
Old 08-14-2017, 06:54 PM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
good to hear, have you considered sending in an oil sample to make sure you don't have any crap in the current oil?
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
  #472
Old 08-14-2017, 07:13 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
I drained the oil, nothing on plug and took apart filter. Don't believe I saw any metal or fluid that shouldn't be there.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s Dyno Proven tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #473
Old 08-14-2017, 08:00 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
you wont see the stuff that harms component's... the big stuff gets cought in filter.. its the stuff smaller then a human hair that takes chit out..
and you won't see foreign fluids either..
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #474
Old 08-14-2017, 08:20 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Send a sample you think?
__________________
  #475
Old 08-15-2017, 05:56 PM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
What do you think?
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #476
Old 08-15-2017, 05:58 PM
bluedge8's Avatar
Colonel
Member's Gallery
Default
No question,
__________________
  #477
Old 08-15-2017, 06:00 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Problem Is that, it would a contaminated sample. Bucket I used had antifreeze in it.
__________________
  #478
Old 08-15-2017, 07:17 PM
bluedge8's Avatar
Colonel
Member's Gallery
Default
hpop res?
__________________
  #479
Old 08-15-2017, 07:30 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Hmmmm? Good idea
How much do I need?
__________________
  #480
Old 08-15-2017, 08:19 PM
bluedge8's Avatar
Colonel
Member's Gallery
Default
Less than a cup
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Designed by Military Ltd
