DIY transmission rebuild kit...
Big Calo
Is there a DIY rebuild kit offered through anyone for an E4OD or 4R100? I think I could rebuild one myself with a decent manual.
brian89
Penisylvania
I got mine from ebay, Alto makes it, ATSG manual and you can't go wrong, in the process of reassembling mine right now, cake walk
brian89
Penisylvania
2, 6 inch pieces that need to fit into the reverse hub in the back of the trans, and when you make your spring compressor they need to thread into the front pump bolt holes, when you go buy the rod, just take the bolts with you and match it, make sure you get a few nuts to lock down the compressor, ill post pics of mine in a bit
