farmall16
All parts are from a 2000 E-450 with a 7.3. 157K miles. All prices are shipped. Sold as is. PayPal accepted. If you need more information or pictures, call/text (585) 519-2579. Nick. Please no calls after 9PM Eastern time.
Van Turbocharger. Very little shaft play. Compressor wheel looks good. Exhaust housing bolts vibrated out. Would recommend a rebuild just to be safe $200
Injector oil spouts and bolts $20
Fuel filter housing $100
HPOP Reservoir with sensors and bolts $55
HPOP gear $25
Dual Pulley Tensioner $20
Van intake Y-pipe (Spyder) $45
Van accelerator pedal assembly with sensors $45
Hydroboost assembly. Plunger, spring and retainer were removed. Good for parts or reuse your old plunger, spring and retainer.(Unable to be tested. Vehicle had a blown brake line) $40
Master Cylinder (Unable to be tested. Vehicle had a blown brake line) $30
E-series oil cooler ends $65
4R100 transmission harness. Van had a transmission mounted parking brake. $75
Belt driven vacuum pump. Newer aftermarket $50
7.3 Engine. Was running when removed. Had a misfire. Possibly fuel related. No injectors, hpop or turbo. Long block. Valve covers and oil pan damaged on removal. Local pickup only. $200
HPOP gear $25
