MBRP Up-Pipes
FaSSt9602
Gilbert, AZ
Anyone seen these or use them yet? Do they have a better than stock collector design? I REALLY like the price @ $280 and I have had nothing but good things to say about MBRP products....
Gadgetguru
Pennsylvania
Had them on for about a week and half. Got them for $238. Seem to be a decent stock replacement. The SS bellows are big and have an interlock lining. I think the welds could have been a little better on the pipes though.
black'n'blue
Did mbrp advertise any Hp gains with using these?
Sent from my HTC One using Tapatalk
FaSSt9602
Gilbert, AZ
That collector looks a little better than stock. I would think they would flow a little better than the stockers. Maybe a drop in EGT's and BP?
i doubt you will see much gain of any kind-just have to replace them less often then stockers.
Gadgetguru
Pennsylvania
Not sure about any gains. The bellow on my stock y-pipe had been bad for a while and had to wait until I could afford a new one. Couldn't beat the deal on the MBRP. Good product for the money.
After installing the MBRP y-pipe it was so much nicer driving my truck. No more high pitched squeal, EGT's dropped back down to where they should be, more responsive and improved boost without the leak. Also I gained .5mpg.
This was my stock y-pipe:
Hit it with some high temp paint I had:
DZL JIM
North East Ohio
Has anyone installed these with the cab on? It's hard to mess up with the cab up, but fit is important with the cab-on.
We did a Y pipe from a known aftermarket supplier that took HOURS to get to fit properly.
...Hit it with some high temp paint I had:
For up-pipes I always prefer a silver or gray. If they are black, and happen to blow the bellows again you'll never see the soot.
Gadgetguru
Pennsylvania
Did mine in my driveway (cab on). Seems to be leak free so far.
Good point about the black paint. I used silver on my exhaust and have found leaks by seeing the soot. Unfortunately I wasn't prepared, all I had was black and needed it done so I could drive to work the next day. I did not however, paint the SS bellows themselves.
f3502wd
Im bumping this thread to see if theres been any issues to date? Its nice to have a set of up pipes with no core charge.
