fuel bowl delete...
oneturboforme
Ok so its kinda pisses me off that elite charges 700 for there delete so I have been doing a lot of research... Okay so the main supply line is reg ol 1/2 fuel line.. so from there I can adapt to AN fittings and house to a reguator... The other lines past the filter are 3/8s which also can be adated to AN fittings... The max pressure that the system will see is 10psi which is set by my airdog... Now.. why wouldn't this work.. you can keep the factory fuel check valave from the heads and ditch most of the banjo fittings ... I guess I might be crazy let me know what you think.... Thanks
oneturboforme
I found a way to bypass the banjo fittings... Now should I keep the fuel cooler or ditch it?
Administrator
im not sure why you would be pissed really, you're paying elite for all the parts, fittings and design, as well as profit. lots of times those prices motivate people such as yourself to figure out another way. theres many ways to skin a cat, hopefully you find a better cheaper way, but you dont HAVE to turn a profit on stuff like this, elite does. good luck!!
if you cant buy it, build it, if you cant build it, wait till you can pay for it... i have said that about.....mmmmm 1000 times i bet.
I dont have a fuel cooler
oneturboforme
Sorry I was a little heated when i posted that.... Elite does some very quality work and im sure there trying to recoup from the R&D that took to make this product.. besides that.. so some say keep the cooler.. others say dont... I do see how cooler fuel is more dense however... Seeing that you dont hqve a fuel cooler.. do you have elites kit or do you have different kit? Thanks
I have a mostly stock fuel system that i modified
The fuel cooler cools return fuel, not supply fuel
The fuel cooler, coolant pump, doesnt even kick on till 160 degrees INLET fuel temp
If you tow alot with under a 1/4 tank of fuel, i could see needing it.
oneturboforme
The fuel cooler cools return fuel not supply fuel
Yes i know about the cooler only cooling the excess unused fuel and not the supply... Wow I didnt know it only kicked on at 160... Thats high... I can only see it being used when idling on a hot day... When I'm towing I imagine most of the fuel is supply and very little will be excess
you would be suprised...
In some cases PCV and VCV are higher percents at idle than going down the road... meaning the pump is by-passing more fuel going down the road than an idle, also making pressure makes heat, so at idle only making 5800 lbs of rail pressure, compared to 13-17k going down the road, thats where the heats at.
fwiw caterpillar says that power isnt effected by fuel temperature untill the fuel temps reach 250 degrees, once they get that hot, the power loss is exponential for every 10 degrees over 250
oneturboforme
Better yet... What about keeping it.. upgrading the pump to run constantly and put and eletric fan on it?
i edited my above post...
Probably a reason it doesnt turn on untill 160, but i would also imagine that cooler fuel means more HP
oneturboforme
Looks like its bypass the fuel cooler and put and temp gauge in line and see how hot it gets...thanks this has helped a bunch
you can read inlet fuel temps with most programmers, i havent hooked mine up to see but i never watched it before, probably a good idea to monitor fuel temps before so you have a baseline for after, i dont tow, so i dont care.
If it only cools the return fuel what benefit is there to ditching it? I would just leave it be.
if the return fuel is hot, and makes the fuel in the tank hot, then it makes the supply fuel hot, like i said under a 1/4 tank of fuel is where i could see some high fuel temps.
I got rid of mine because it was much easier to run piping
Administrator
i'd like to ditch mine.... i hate that extra crap and plumbing under my hood.
oneturboforme
Another thought to ponder... Since the fuel bowl isn't there, there isnt a quart of fuel thats getting heated, just the intake fuel.. so the heat cycle wouldnt be so bad.. and id like to get rid of it to clean my motor up a little
SEABEE08FX4
Montgomery TX
Just to clarify I meant in removing the cooler not the bowl. I plan on deleting the fuel bowl on mine as well.
Administrator
i dont have a bowl either... i highly doubt that is a major contributing factor though. i'd love to get rid of the cooler and the resevoir. convince me dustin.
