My rebuild/build tired of being basic
Hendrys2009
Baytown, Tx
Well I decided that I better feed my cp3 in my dual fueler set up with a seperate lpfp so I can keep it happy with lower fuel pressure. I went with a fass 200 and a fass sump kit. Drilling a 2" hole in the bottom of the tank of a truck with less than 18k on the clock will deffinatly get you to check your measurements multiple times.
powerstroke22
Long Island, NY
Set my truck up the same way works well, I would recommend putting a fuel pressure gauge in the fass port so you know when its getting ready to **** the bed.
Hendrys2009
Baytown, Tx
Any reason you didn't go with the new H&S LPFS kit?
I needed something quick, Im trying to get my truck going before the 20th for tsd's dyno event.
I know that's right. already in the works. Not many gauge pods available for these trucks.
Hendrys2009
Baytown, Tx
As per mr. Joey's request I will update this. Been working my butt off everyday after work trying to have it ready for tsd this weekend.
Hendrys2009
Baytown, Tx
I still have to plumb the cp3 and change/ fill all my fluids and download my tunes I got from tsd and it should be ready to fire!
