Wheel/Tire Tech Thread
Bakwoodz
I'm sure I could cram the 35's in with just a 2.5-3" leveling kit but I don't care for the stuffed look. If the tires look to small in the wheel well then when they are needing replaced I'll go to a slightly larger tire.
strokinpower
Greensboro, NC
well I'm happy with the 20x9 0 offsets
bigsmokey531
NY
I know of a guy who put 420s on a 24x14... but youre probably not looking for that small.
Looking for a M/T or A/T like 35" or 36" for a 24 but there very limited on tires for that size wheel. Even if I gotta stretch it Idc haha
deiter5262
Kansas City, MO
I followed your questions here. I just did a swap to 3.5" Fabtech lift with 3.5" blocks in the rear and new calibrated Bilsteins. I am running 20x10 Fuel Throttles Deep lip with -24 Offset on Nitto G2's 35x12.5's. At full lock or if on incline hill my tire will rub inner fender only. I need to full fenders back or trim a little. I love the look. A 4" lift will be enough to clear 35's. A lot of it does have to do with your wheel offset also. My truck has perfect wheel/ tire and gap combo if you ask me. Not stuffed and not too little either. I'll post a pic up below.
nice truck!
deiter5262
Kansas City, MO
Here is my recently converted 2003 6.0. Current brand new set up is 20x10 Fuel Throttles -24 offset deep lip wheels with Nitto G2's 35X12.5x20. Lift is 3.5" fabtech and matching rear blocks on stock '03 springs. Minor rubbing on inner fender, I will get that fixed this weekend. Fitment turned out perfect.
Ricky218
Stock height, Fuel Octanes 20x12 -44offset w/Nitto 305/55/20 Terra Grapplers
Gunner7298
Well here's the Ox as she sits now.
2012 F250 CCSB, 4in Zone radius arm lift, 20x10 Centerline Scout polished rims with -25 offset, and 37x13.50x20 Toyo MTs. Front bumper bracket was removed and I did minor trimming to the factory fender flare to alleviate any rubbing. I can turn full lock both ways without any rubbing. It does however rub if I hit a bump hard while turning sharp or backing up at full lock but it's all rubbing on the inner plastic liner.
Sent from the wild blue yonder....
Most perfect looking badass truck I've seen.:rockon:
Ricky218
Damn right, same setup as mine! Can't beat that look man!
I pm'd you a few weeks back asking you about any rubbing issues. Once you confirmed that the setup would work with minor trimming, I was sold! so happy how it turned out. Thanks again:thumbsup:
bft blue oval boys
Burlington, NC
Oh Yea! Lol. Skipped right over the username and went straight for the awesome pics lol. Glad I could help man
Austin, Tx
2000 F-350. Completely stock F-350 height. 20x10 with 0mm offset Weld Cheyennes and 305/55R20 Toyo AT2. Tires rub at full lock turning to the right only.
Sent from my SAMSUNG-SGH-I337
Austin, Tx
Looks sharp! How far do the tires stick out?
Thanks! The tread is about 3/8-1/2" outside the fender at the top and at the bottom of the fender the tread is about 2" outside the fender. I didn't want them to stick out much in hopes of saving my new paint from rocks.
Gunner7298
Put them on. Had to modify the front lower bumper basket on both sides. Also had to trim inside the fender (the felt) on both sides. No scrubbing now. Completely stock height. Wheels 20x10 -24 offset 35x12.50 Nitto grappler MT's. Looks really good in person. Adding flares and 2" level kit next week...
looks really good.. Thats the exact same size setup i wanna go with and good to know it will fit stock suspension.
