my build/weight reduction thread.
leland88
Warman Saskatchewan Canada
well i had 5 hours today to start deleting my truck.
i started off with the no limit EGR delete kit. then i did the no limits inter-cooler and the H&S inter-cooler piping.
everything is well made and fit in place perfectly.
my plans tomorrow are in install the no limit CCV, intake,flo pro 5" exhaust and wire my cts up with the egt sensor.
i will post some picture of of the install shortly (not a how to or anything just un boxing and installed pictures)
Administrator
i started off with the no limits EGR delete kit. then i did the no limits inter-cooler and the H&S inter-cooler piping.
my plans tomorrow are in install the no limits CCV, intake,flo pro 5" exhaust and wire my cts up with the egt sensor.
yeah buddy enjoy ! you're truck is gonna be ALOT stronger. just a heads up there's no "s" after limit :)
leland88
leland88
Well I got it all done minus a couple things I'm going to fix later on. Took 14 hrs start to finish. I have one question. The plugs for the egr on the motor and the dpf plugs and lines I should tape them up??
Sent from my SM-G900W8 using Tapatalk
Ctsvnino
North jersey
Yes die electric grease and electrical tape
Jacob @ No Limit
Indiana
Yes dielectric grease and tape and make sure they are sealed. Mine corroded and caused me some issues cause I just left them alone.
leland88
pictures
