Wheel/Tire Tech Thread
psduser1
on the road
03 ex got some new shoes. Mt 058s, powdercoat ed black, 5" backspace. 33x12.50 (305/50) mounted on a 20x10.
Had to trim or remove the plastic air dam under the bumper, tires hit it at full lock.
fordmansteven
craigsville va
I have a 2015 ccsb and I am thinking about putting a 2.5 leveling kit on it or possibly a 3 in kit. I am planning on putting 20 x 12 American force rebel ss 8 on it and 35x12.5 tires, will they rub. If so what size tire and rim do yall recommend I run so that it doesn't rub
Squat and Poot
Houston, TX
theyre going to rub but if you remove the front bumper bracket and pull back the rear of the liner you could clear but maybe not full lock
I have 22x12 w/ 325/50r22 and they rubbed with 4.5" lift
you will need to pull back fender liners and trim bumper bracket. it is literally no biggie
LukeDuke
Charleston, SC
I've just looked through all 56 pages of this thread and did not see a single dually! Any dually owners have a nice wheel/tire package they want to share? I'm due for some new tires and I'm wanting some ideas for my 08.
I have a 2014 F350 DRW. I'm at work now, but will find the pics for you.
LukeDuke
Charleston, SC
Dually wheels
2014 F350 DRW Platinum w/ 3 inch Ready lift. Its sitting on 22" Fuel Dually Mavs, wrapped with 35x12.50 Toyo M/Ts. Each wheel has a different offset (Front +127mm. Rear inner +128mm. Rear outer -215mm). No rubbing anywhere. No cutting needed (unless you put mud flaps on the front).
I'm looking to put 37s on the next go round. :shocked:
Tom@BigTimeKustomz
Bayville, NJ
2013 F350 CC/LB. 2.5" Daystar level up front, 20x10 Fuel Couplers with -24 offset, 35x12.50R20 Toyo A/T tires. Trimmed bumper bracket and inner fender liner a bit, still rubs a little at full lock on uneven ground, usually when turning. Have a 5" block for it coming as it sits nose high.
dsberman94
Pennsylvania
Tax return came in and I decided to put it into the truck. Grabbed some 16x10 -25 offset raceline renegades. Tires are 285/75. Rub the rear fender liners just a touch on full lock. Nothing crazy sized but I like the look of having a lot of sidewall.
dsberman94
Pennsylvania
Both. But a lot more rust than mud. The fender flares are sitting in the living room waiting for me to get the vinyl that's covering up the two tone and the flares. Don't want them chipped or dirty before I put that stuff on. Went with egr flares. No rivets or anything like that.
donhue
North carolina
Anyone have any pics of a 99-03 with a leveling kit, 20x10s -24mm offset and 35x12.5s? desperate need of info getting wheels and tires at the end of the week and need to know what im going to have to go with
PwrStrkd73
Can someone tell me what wheels are on my truck, the backspacing, and offset? Also, is the offset and backspacing correct for this truck? The truck is a 2000 F-350 CCLB with 6" Rough Country lift. The PO installed the lift new and bought the current tires {37x13.50x18 Nitto Mud Grappler's} and wheels used on Craigslist. I'm wondering if the rims are correct b/c the tires rub the leaf spring at full lock. I thought a 6" lift should clear the 37's, but maybe the wheels are backspaced or offset incorrectly, or it's just the big side cleats on the Grapplers causing it.
The tires will need to be replaced soon and I've always liked the black RockStar's, so if the rims aren't right I might just go with them and either 35x12.50's or the metric equivalent of 36x13 {315-70R18} Toyo Open Country MT's.
black'n'blue
A lift will not give you clearance on your leaf springs. Only thing you could change is wheel offset or use a spacer and tire height/width. Or do the 05 axle swap and lose the leafs all together
PwrStrkd73
Thanks, I was just meaning I see a lot of guys running that size. I also put my truck and lift into the tire & wheel package on Rimzone and it came back with the Mud Grapplers in that size as being compatible. I mostly want to know if the wheels are backspaced correctly {i know the '05+ coil-springs trucks have about 2" more backspacing stock, but i think these are close to what I've seen online as the factory backspacing for 99-04's at about 4.5"} and if anyone knows who made the wheels or which model they are.
