Wheel/Tire Tech Thread
6fourstroker
Guys did any of you (like myself) screw up and get +18 offset instead of -18 or -24?? I got 20x9 on 35x12.5 mastercraft mxt and they barely stick out.. What is my best option for getting them out there a little bit? Maybe an inch? 1.5"?? I know the answer to that is spacers but is anybody running them reliably ?
white07psd
ImageUploadedByTapatalk1437973496.477419.jpg 33x12.50x20 toyos on 20x12 welds
ImageUploadedByTapatalk1437973634.462108.jpg33x14x16.5 boggers on 16.5x14 welds
white07psd
I run 2" wheel spacers with both my 20x12s and 16.5x14s. Knocked out the cheap studs and installed oem ford studs in the spacers. 198k miles and only have put passenger side balljoints in and steering box recently since truck was brand new. I dont tow with this truck also
6fourstroker
Thanks for the info man, truck looks killer too! 🏻
tbrown1986
Joplin, MO
2005 Crew Cab Short Bed Dually
2.5" readylift spacers up front
2" daystar blocks in the back
20x8.5 Fuel Mevericks with the "street" offset
275/65R20 Nitto Exo Grapplers
talentsearch301
North Carolina
Quick question
When changing rims from factory to aftermarket 20's and tires to Toyo AT2's 35 /12.50/20's
Do I use the same air pressure recommended in the door jams for stockers?
Powersmoke_sd
Glendale, OR
What's the door say? On my 2000, runnin 37's with 20's I run 40psi, on my 2006 with 35's and 18's I run 60psi. The 06 has stock 18's with 35x11.50x18 toyo AT2's.
Coueshunter
Gilbert, Az
Be a bit before they get mounted. 20x10 BMF REPR wheels. Getting 37x13.50-20 Toyo MT tires with a 6" PMF lift
java
I love a short bed dually! Looks good buddy!
tbrown1986
Joplin, MO
^^^^^ Thanks man! I appreciate it! I think I've got it looking pretty good now. Just had it head studded last week. It sucked driving a stock 6.0 around....
ckrueg
Belding MI
Quick question
Usually you will have to drop pressure on bigger tires. I'm running 295/65 r20 toyo at2s on my truck. Dropped the fronts from 70 to 60 and the back down to 42 to even get the shoulders of the tire to touch the ground. If your heavily loaded or towing you obviously will want to air them up to max though.
slc6oh
Utah
Been lookin through all these damn pages and cant find what im lookin for. haha
request is:
05-07 leveled on 22x10s... -24 offset...
is it possible? (35" tire)
