Purchased a smashed 2015 6.7......
pdumont01
CT
I'll take some pics. A fire truck hit it. Bent the front right side radiator frame, bent the front axle trackbar into a bow, snapped off the sway bar links, took out the pass bed side demolished the fiberglass fender lol, and the radius arm bracket to the frame got bent ruined the radius arm and also the arm hit the oil filter lost all the oil truck idled till someone shut it off and then engine was locked up. I had to use the starter and a pry bar to budge the crank to get the converter nuts, I had the starter in and out 6 times
Sent from my Nexus 6 using Tapatalk
dsmracing1
Alberta, Canada
Great job on tackling this project! Been following this one from the start....
Blown262
Long island, NY
Did you get this truck from an auction house near Pittsburgh, PA? One of my high school buddies is a firefighter out there and got smashed by a new superduty in a firetruck he was driving.
Wow, frame not bent?
pdumont01
CT
Frame looks surprisingly well. Ill post some pics when I go back to the shop. I believe the truck was from new York. Was a construction company vehicle. It is a crew cab dually black metallic not sure what the name is. I'm going to nursing school right now after being a ford senior master diesel tech for ten years(go figure), so project is going a little slow.
Smart, a/c cooled job. No physical labor, cleaner job. And better pay. Don't blame you one bit.
pdumont01
CT
Yeah I love working on stuff especially powerstrokes, but in the end when I'm 50 I don't want to be contorting my body in all kinds of crazy positions. I feel it already lol
pdumont01
CT
Well got to the shop today and put in a few hours, started with one head torqued ended with engine sitting in truck
someone fixed the rear end
fender is under a pile of parts
going to cut the rivets already have new bracket, arm, and bolts
links snapped off both sides
I'll post a pic of the bent track bar next to the new one when I get it out
you can kinda see the front radiator support bent hopefully we can fix it with the bobcat
Ready to install
on the way in......and at that I forgot to snap a pic of it sitting in the truck. I'll be back at it 6am tomorrow!!
pdumont01
CT
Are you keeping the factory turbo or is it damaged? Interested in selling it?
Re-using it sorry. I tried to talk my buddy into getting rods pistons Dual pump and a bigger turbo but he opted for the head studs only. :-(
I personally would have overdone it but he wanted the engine warranty still.
pdumont01
CT
Got some more done today.....
The rest of the parts
And now off for some fun for the rest of the day, should be running this week!!!
pdumont01
CT
The beast.....should be working on it some more this week. I'll post a startup video...as long as it sounds good lol.
Worked on the 650 a little today did some brake lines.
pdumont01
CT
And now if someone could tell me where all these extra parts go.............lol
pdumont01
CT
Its about that time..................
pdumont01
CT
Well its running great my job is done......for now, will be getting the ******* tunes, 5inch exhaust , intake (anyone have a recommendation??), egr ******, *** ******, gooseneck hitch, and maybe a lil lift.
https://youtu.be/IDxHwljg-n0
PM Mike for an intake. (Nolimitfabrication.com)
pdumont01
CT
Pics will be up after it comes back from the body shop.
pdumont01
CT
Here she is looking like a truck again......somewhat
