The 2011-16 Leveled Super Duty Thread
Tim1216
Pittsburgh, PA
2011 F350
2.5" spacer in the front
Stock blocks in the rear
Fox 2.0 shocks all the way around
35x12.5R20 Terra Grappler G2s
20x10 Fuel Mavericks (-12mm offset)
That looks great. Do you have a side picture? Does it sit level? How is the ride? Sorry for all the questions, but this is the exact set up i wanna do with mine except I want 18" wheels
bigogre
Massillon, OH
Thanks man! The only two side pictures I have are with the old tires on it. It still sits the same though. The front end is around 1/2" lower than the rear and it doesn't really ride much different than it did stock. The Fox shocks made a big difference when I installed them, but my factory Ranchos were pretty worn out.
Tim1216
Pittsburgh, PA
Sweet thanks! Yeah that's perfect. I just wanna level the front end out and put 35s on it. And my shocks have 135k on them, so I'm gonna replace them and the fox shocks should ride a lot better
W8KSK8
I have the Carli leveling kit with tuned bilsteins and added the rear shocks into the package. It's a 2014 f-250 with the camper leafs in the rear and the 3 5/8" block from factory so it's pretty much a f-350. These are 35x12.5r20 Toyo R/T's. I can't tell you how it rides yet as it just got done and I'm on a boat in the Gulf of Mexico but my expectations are high I can't wait to drive it!
Tim1216
Pittsburgh, PA
I have the snow plow prep package. Does anyone else on here have a 350 with plow prep? It looks like mine sits a little higher in the front and I should only need about 1.5" in front to have it level. Any input would be appreciated!
Stackedup6.7
I just ordered the same tires curious to hear how they ride and sound. Looks good!
jwalk09
VA
Little update on mine. 22 novas with toyos.
jwalk09
VA
I cant remember, did you swap the rear pack? I think I remember you saying no... but what do i know...
No I just have the blocks. I only plan on adding traction bars and new shocks for the rear.
UNBROKEN
Here's mine: 2.5" icon coils, 1" PMF bottom mount spacer, Carli Commuter Fox 2.0s, 3link, 4" traction blocks and 17" BMF DRTs with 37x13.50 Toyo RTs.
I keep going back to look at this thing. Makes me wanna buck the trend and run a 17/35 combo.
CATDiezel
It's not a trend Richard.... it's a matter of your truck looking proportionally correct!! A platinum with 17's would be like an OBS guy with a 7.3L yanking it and putting in a 6.9l na-idi. Lol
Squat and Poot
Houston, TX
If I were to go from a 2.5 coil to a 2.5" coil w/ a 1" spacer what else do I need to add to the truck?
front driveshaft shim?
brake lines brackets?
ALAs for axle placement?
etc?
