6.7 high idle switch with upfitter
Jonny72888
Hey guys, I had some time today and added the high idle to my truck. Works off the upfitter #3 with either the key or factory remote start.
2016 f350 6.7
slim!
767 miles on the truck, you wasted no time getting this done!
very slick tho
CATDiezel
And prevent wet stacking.
Sent from my XT1585 using Tapatalk
Although that holds value on older rigs, wet stacking is almost a non-issue with a piezo injector truck. More of a help would be the vanes closing off and adding back pressure to an idling truck. But the computer already does that somewhat.
Powerstroked6.7
Washinton
I see most people use auxiliary 4 15 amp, auxiliary 3 works fine?, I would like to save auxiliary 4 for something else, looks like you used the brake by pass set up also, planning on doing mine this weekend
Powerstroked6.7
Washinton
I hooked mine up exactly like the video, but mine doesn't work like the one in the video, when I flip the upfitter switch the idle jumps to 900 rpm and then will only adjust to 950 rpm, any thoughts about this
