dsberman94
Pennsylvania
Installed the productivity screen today everything works as if it were from factory
What did it look like before?
slowcoupe
Las Vegas, NV
Pulled apart the factory headlights, did paint to match on housings tuxedo black and pale adobe metallic. painted the orange marker light with the running W logo negative space, lights up nice with a small led bulb behind it. added the led strips also, they are switchbacks with amber turn signals, the white is a little bit more purple than I had hoped but looks good. don't mind the info in my sig, ill update it.
Damn those turned out great!!!!
Mike_D
Northern, CA
Ordered a set of 6" traction blocks from Jared @ One Up Offroad. Going to replace my 8" blocks and drop the front coil overs down a bit as well. Little weekend project.
Also, finally ordered a No Limit intake from Luke @ Miller Performance.
Rubenk
KCMO
Took first place in Diesel 4x4 heads up races last night. Weather was terrible so everyone's times were terrible. I barely cracked 11's on one pass, rest were low 12s. Should have been several 11 second trucks there, but literally the worst conditions i've ever raced in. 98 degrees and ~80% humidity. Track temp was 135 degrees when we started racing...
RSK
Connecticut
Picked it up from the body shop, finally got some paint to match bumpers on the old work truck!
Here it is when it was pretty much stock
RSK
Connecticut
That is sexy as f###... Have had same plans for my reg cab. Just haven't done it yet..
Thanks, it's harley davidson grille i had them paint that way if you decide to do it, and you can't buy one blank from from ford, have to buy it blue or black and chrome
smcox1
I kind of miss the look of the black bumper on that truck. Still looks good though.
7.3powerstroke00
Brownwood
Is that not basically the same as the fx4 grille?
