WhiteMamba_Scorpion
"Radiator Air Deflector" that goes from the bumper to the bottom of the radiator for a 2012 F350 6.7 the part number I was given from Ford Parts was 8327. Just wanted to make sure this was correct and how much for it including shipping to Ohio. Thanks.
sunrisefordparts
you would be looking $29.17 to your door.
blk99
Need a price on all the parts needed to put a rear sway bar on a 2016 F350 CCLB SRW 4x4
I dont understand why it didnt come with one from the factory.... LOL
Sent from my SM-G920V using Tapatalk
sunrisefordparts
heres the quote, shouldn't be anything else I can tell in the picture that you will need.
  • Q442978.pdf
WHY NOT
Carlyle IL
Can I get a price on what it would take to do 13+ brake conversion to my truck. I guess that would include new front spindles with ball joints, new calipers front and rear, slide pins front and rear, and brackets front and rear. No need to price pads, rotors, or lines as I will get those aftermarket.
-Thanks
Matt
these part numbers are from fordparts.com.
need a quote shipped to 13057
3A131
3304
3A130A
3A130B
and the miscellaneous hardware that goes with it minus the cotter pin.. have boxes of those at work.
need trac bar ball jojnt too
part # 3050
Mike_D
Northern, CA
3C3Z6C755AA
Hoping this is correct for the oil filter anti drain back. 2008 6.4 job 2.
If you have one in stock, can send PayPal ASAP. Thanks!
sunrisefordparts
3A131
3304
3A130A
3A130B
part # 3050
rather not to assume and be wrong what truck are we working on?
sunrisefordparts
-Thanks
Matt
heres the quote for ya, the rear brackets show in the catalog to possibly come with slide pins but I priced them incase ford strikes again and has false info in their system.
  • q444491.pdf
sunrisefordparts
3C3Z6C755AA
that number is the oil filter stand pipe, for the drain valve your looking 3c3z-6800-a and cost $7.25 we show to have in stock. whats your email and ill send it right over.
