Any of you done studds and gaskets with the cab on? I can do the work myself, but I have no way to remove the cab so I would have to do it with the cab on if its doable for the average Joe. AND if any of you have done it.. would you do it again?
I never pull the cabs on a 6.0, always take the motor out through the front. Reason is, every truck I do headgaskets on gets a new set of lifters, which requires the rear cover to be removed.
So then I take it your on the lifters fail side as opposed to the cam failing first side? I'm still perplexed on this issue
I believe it's lifter first.
Its all good Matt... I'm trying to hold out as long as possible..no worries.Sorry for the long wait times man! Dillon at Webb Transportation would be able to get you taken care of no problem. Good people.
