Hfcm not running?
6fodays
va
Alright haven't posted for a while. When i hit the key i hear no lift pump and when i get down to feel the pump i cant feel it running. Is the hfcm a flow through design allowing my k16 to pull the fuel on its own? I feel like i should at least hear or feel it running. Or does the hfcm only kick on when the truck is started.
DEEZUZ
NO PUKESTERS
NWI
it should run for ~ 30 seconds upon key on. Did you just change filters? the relay clicking is more audible than the pump itself.
6fodays
va
I bought the truck on friday. Filters were changed before i bought it. I don't hear any relay or motor running with key on
6fodays
va
Yea truck runs fine. Any way to check outlet psi at the hfcm?
Put a gauge on the Schraeder valve at the fuel cooler under the hood
6fodays
va
Would that read low pressure fuel with key on engine off? I thought it was only return fuel straight from hpfp
It should. It's a closed loop system.
