Edge filter or no edge filter
Mtack
Pomeroy, Ohio
I bought a 95 ECLB last week because the previous owner couldn't get it running. It had been at a shop that works on Cummins with little knowledge of Powerstrokes. I have chased it down to the IPR. It has a newer IPR valve on it with no edge filter. The original one is laying in the floor and has the edge filter. Which one do I need or does it matter?
Magnum PD
VA
Which HPO pump is on it? Original or newer?
If it is newer style, the edge filter will be behind a plug on the left bottom of the pump.
Mtack
Pomeroy, Ohio
No idea. I've been working a lot and had barely any time for it. The reason for my question is that the local Ford dealer said the IPR with the edge filter has been discontinued and they replace all of them with non edge IPRs.
Sent from my ONEPLUS A3000 using Tapatalk
