6.4 Gone. 2017 6.7 F350 Platinum In.
Here's mine currently. Driver and passenger side.
yup, now i know i definitely need new shocks. i bottom out on one bump everyday on my way to the shop. stock hight 2012 f350. but only above 65 mph.
redracer62
Decided to reverse level this truck. Got new U-bolts in today. Thanks Jomax for getting me the right part #. Will get the blocks out and get the rear dropped on Saturday. Will just have to figure out shocks after this. Think I might try some 2.5" shocks to see what all the fuss about them is.
By chance do you remember what you torqued the ubolts to? I’m gonna do mine soon
Black AOD
Ohio
I think 175 ft-lbs. FYI those ones you quoted are for F250 with rear block removal and NO top overload. I had to return those and get different ones because I have a 350 with top overloads.
redracer62
Ok thanks! I’m doing mine a little different than yours. I was mainly curious what you torqued them to. Truck looks good btw!:rockon:
Black AOD
Ohio
No problem. And thank you! What's the plan for yours?
redracer62
Mines leveled on 35’s now. The back is still a little high for me so I’m getting some blocks off a dually I think. There like an inch shorter than mine now so it should be better looking after. Then I’ll get some real shocks after that.
bluedge8
Champlin MN
Our lugnuts require 165ft lbs. Doesn’t seem to high at all really.
They verified it, the 9/16" u bolts on my '96 are 99 ft lbs so it just caught me off guard.
Black AOD
Ohio
So not a whole lot has happened. A little bit has though.
Got some PTM work done. Weather has been garbage for a week straight now so Haven't been able to get the truck washed and looking right for pictures so these will have to suffice for now.
Did all the following trim pieces Shadow Black to match the truck.
Mirror Caps, F350 Side Badges, Top and Bottom Grille Pieces, Door Handles, Rear Platinum Tailgate Badge.
Picked up Shones Tinted Tail Lights which look awesome on the truck.
Also picked up a Smoked Third Brake light.
Picked up a set of PTM Emblems as well. They are off being Clear filmed right now (to prevent rock chips) so they aren't on the truck right now but I posted some pics down below.
I also swapped the 4wd Valence for a 2wd valence.
Need to pull my tow hooks and have them powder coated black. After that, all that's left is to get some PTM headlights and mirror marker lights done by Jeremy at Retro Customz. The plan is to replicate them like the screen shot pictures below.
Black AOD
Ohio
Yeah it hasn't been dleeted yet
Not worried about that right now nor will it probably happen until the warranty is out
RSK
Connecticut
Looks badass i might have to hit up the retroshop for my emblems
Black AOD
Ohio
CTS did my emblems. I'm having a local detailing shop do PPF on them so they don't chip or flake like my last emblems did.
