m_j
rebuilt a 2008 rear with a Grizzly locker. third Grizzly I have installed in ford trucks
greyford1979
Copley,Ohio
Took it out for some snow wheeling tonight, now it needs a bath. I think there's about of foot of snow/ice caked on the tube steps lol. Actually made it kinda harder to open my door since it was up past the bottom of the door.
501 96 7.3
Arkansas
Fixed Oring at the dipstick, not to bad of a job.
florida 6.0
florida
Oil pan gaskets . Valve cover leak found and fixed and new glow plugs and harnesses . Long day but hopefully no more leaks . I don't mind a few drips but she was leaking like a mofo lol .
Tn
were you able to get the pan off or just kind of work around it? I have one with some serious rust and I am waiting for the day it starts leaking and needs replaced.
Mesa, AZ
You can get them off, I typically drop the pickup tube into the lower pan and then pull both pans at the same time. Takes some tetrising to get under the trans/rear cover to remove them, but it will fit.
florida 6.0
florida
Thanks, sure not looking forward to it.
Plenty of videos on you tube for good tips and tricks . I did it on my back but my trucks lifted so it wasn't too bad . You can get the pan and the aluminum pan adapter off by raising the motor an inch and pulling the pickup tube
. I put 1" blocks under the motor mounts and then let it down so the jacks were not in my way . The hard part was figuring out what to take off so it didn't get damaged .
79jasper
skiatook, Oklahoma
I they are talking about the 6.0, since upper and lower oil pan were mentioned, but it's doable with the 7.3 as well.
Sent from my SM-N960U using Tapatalk
Connor M
Masshole
Took it to the tint guy.
5% fronts and 25% over factory in the rear.
Probably would have done 20% over the rear next time or even just 5% all around. Little bit lighter in the rear than the front, but you can only tell from inside.
I just got a fix it ticket for my 10%. Going back to 15%
Connor M
Masshole
I’m way below the state limit.
Legal here is 35% on the meter which is like 40% film. (Glass reflects a little light)
I had 20% film on my yukon and I thought it was too light. I’m not after dark tint for the sake of having dark tint, I want the heat rejection and privacy. I always wear sunglasses.
Plus I can pick my nose in traffic now LOL
I’m on the same boat. I carry expensive electronics as I work in the media entertainment industry. And do not want prying eyes.
Use ceramic then. Its lighter than carbon but blocks far more heat
Connor M
Masshole
My installer has a clear heat film, I’m pretty sure. I’m considering doing it on the windshield.
