Can you replace a pigtail on a 6.7?
SpyderX
Boaz, Alabama
I keep getting a code for P0672. Glow plug circuit short. It seems you have to replace the whole harness from what I’m seeing. Anyone ever had this issue?
ckrueg
Belding MI
I've seen where one of the NOX sensor module plug shorts out and causes this.
Sent from my LM-V450 using Tapatalk
Mesa, AZ
672 should be open glow plug. Seen plenty of glow plugs fail on 6.7s lately...
Mesa, AZ
Had the whole bank replaced and the code came back.
Which side did they do? The numbering is different on the 6.7s from all the other diesels.
The pigtail is available.
Disconnect the plug on the pcm, closest to the the engine, clear the codes and see if it come back
SpyderX
Boaz, Alabama
Sweet! I appreciate it.
They did the passenger side.
