- Joined
- Oct 3, 2012
- Messages
- 11,842
- Reaction score
- 33
I know, right. Youd think they have learned by now.
Sent from my SM-N975U using Tapatalk
They fail in stock form?
Not commonly but some.They fail in stock form?
I bought a set for my 2011. Turbo started surging/fluttering under steady throttle up a hill with or without a trailer at 52-54 mph just like it's laid out in TSB 11-12-14. So while I'm in this far replacing to an updated '14 turbo and WW2 (make fun of me if you wish) I was going to do the studs and manifolds for reliability after hearing about them being fairly common to break and hopefully some performance (wasn't too much more expensive than stock replacements). I asked BD about what to expect and got a nondescript:
"Our manifolds improve on the reliability of the Ford manifold, while improving the radius’s from each cylinder."
It will be mid June before I get them in the truck but they look good in person. I can let you know more after install. I don't think I will be able to pinpoint specifics on performance of the manifold upgrade though since I have more changes going on at the same time.
I don't know where a 2011 pulls EBP so I can't help there. I would say it's not going to be just one overall.
Fuel Pressure, Boost, EGT, EBP (if location is known), MAF. The Boost/EBP ratio would be good data to collect. If 2011 EBP is pre-turbo that would be awesome.
Post mods I'd say if the turbo/motor was more responsive there may be a drop across the board to which I'd say that shows a flow path improvement.
I know I'd pull up whatever PIDs seem reasonable with whatever device you are using. Then just data log the info. Maybe down the road there could be some targeted PID collection while dropping others off.
I got the new CTS3 which gives me plenty of data to follow. You are doing alot of mods. I doubt we could say XXXX changed it the most but the overall package can be shown to have an significant impact. Sure people want to buy one thing and get the best result. People need to realize there's more than one thing that makes great gains.
I did not read all this but I bought a set as I was putting the motor back together and I found out the stock ones were not true anymore. Did not know that but I suppose when Cody had truck getting compounds that pass side was changed to 16+. Anyway I got lucky and BD sold me the new pass side while it was still a R&D part. They are beast compared to stock.
Believe it or not had more clearance on head studs than factory.
Are you the guy that bought Cody Gorman's regular cab truck AKA Morgan Primm's 2011 white regular cab ?
Hows that thing doing? New motor right?
Nice. Is it still the same turbos and fueling as it had when You bought it ?New motor and trans, slowly going back together and redoing somethings when I have time. Now have to pull trans again and send back. Thought about trips but just need to get it back together as it is covering half my shop.
