I've got a 1996 leaking water. This is the second one and was wondering if anyone else had this problem or I'm just lucky. It's cracked right behind the top oil cooler mounting threaded hole.
the crack makes a "L" shape, runs along the water port then goes up to the thread.
Any Ideas? Just resealed the oil cooler, as it had been leaking oil. This winter had a water leak when it was cold, but dried up after it ran a while. Thought it might be the water pump, but after I cleaned the area, maybe it was this leaking? Sucks, cause I gotta pull the engine again!
