Well, that explains a few things...
Power Hungry
Winder, GA
I was finally getting around to completing my pressure testing and wouldn't you know it, I suddenly developed a dead cylinder. I'm like, "WTF? Is this really happening?" A quick DTC check showed #5 cylinder fault, so that gave me a good starting point.
I figured since I had the new injectors from Full Force sitting on the tool box, now would be as good a time as any to install the injectors. So, armed with lots of caffeine, I got the top end torn off and proceeded to swap out the injectors.
Here's what I found...
(click on image to enlarge)
Any guesses as to why #5 was dead? LOL Of course, this means that my plans for pre-testing ICP & FRP with the stock injectors are now scuttled. :( Fortunately, these injectors are stock nozzles so there should still be some useful data we can obtain between the ICP tests and FRP tests, but I was really hoping to see what kind of valid power gains we'd see with simple modifications to the fuel and HPO systems. All we're really left with now is validation testing for the HPODS, which will still be extremely useful.
Ah well... the best laid plans of mice and men and all that stuff.
Extended Power
I had that happen too.
But, believe it or not, I found the nut right beside the valve spring...just waiting for me to use a pair of fine needle nose pliers to pick it out of there.
See...I have had some good luck too...lol.
Mdub707
Mohawk NY
Red loctite is your friend on those guys...
I've heard of this more than a few times now.
U235a4
Sadly, the nut was nowhere to be found. I assume it's in the oil pan now. :( Ah well. Drive it until it breaks.
It's funny you say this a buddy of mine was working on his truck doing injectors 6 years ago and finally 6 years later his lost torx bit got suck up into the oil pump and sent metal throught LPOS. here are some pics.
ToMang07
Mainah!
You know what they say: If you want to hear God laugh, tell him your plans. :blah:
Vengeance
So your saying the little jaunt around the parking lot the truck was only hittin on 7?
Nice!
