19.67 mpg ! yay
Jason84
Green Bay, WI
Had to go on a few hour drive for work today on the highway... doing 65 mph stock height/tires got 19.67 mpg. Pretty happy with that !
David S.
thats highly impressive. Do you have a f250 or a 350? any weight in the bed? hand calculated im assuming?
pog
psa
Must be hand calc dont recall lie-o going to the hundreth decimal
David S.
i found the best mileage keeping the RPM's under 2000, around 1700 or so to be exact
I've noticed that as well. Especially with fuel the way it is I'm going alot slower now, rpm's low and not getting off the line quick
David S.
I need to learn how to hand calculate, whats the formula? is the lie-o-meter usually below what your actually getting or above?
JDub
Hooper, Utah
Lie-O-Meter is usually high.
To hand calculate, take the miles you've driven and divide that by the gallons of fuel used.
Spatel23
Olive Branch, MS
:whs:
I usually top off to the point where I see fuel in the neck before a long road trip. Reset the trip meter to 0. When I get where Im going I fill up to the top again. Divide the number of miles you drove by the number of gallons of fuel you just put in the tank and you have your hand calculated MPG.
