David S.
- Joined
- May 24, 2011
- Messages
- 1,870
- Reaction score
- 0
How much HP is achieveable with the nozzles? Anybody running these? ANy complaints?
i sprayed to 800 hp on 60s smoke was minimal cold starts were fine ran smooth on them. Probably enough fuel for most people
that's all I needed to know then. It won't be for a while but it'll happen eventuallyBFT i would WG if you are planning on doing larger turbos...
wow thats plenty for me then. What jet and fuel system? Which turbos?
You put down 599 didn't you Jeff with an airdog and stock turbos and injectors? My initial plans for this winter are injectors, airdog II, egr delete with wastegate, studs, CFM + intake elbow and ported rails
595 on Dunbar's dyno and 630 on Rudy's dyno. Only fuel system mods are an Air Dog (without the Elite fuel line kit) and ported fuel rails. EGR coolers are deleted and I have a CFM+ intake elbow. Other than that it's just a SunCoast, tuner, exhaust, and intake.
that was on a big single 76mm and three small stages (about .110 total nitrous)
