Chvyrkr
- Joined
- May 18, 2011
- Messages
- 2,204
- Reaction score
- 0
Its even easier when you don't have the frame and wheels to work around
Engine stands are a wonderful thing !
Kinda like?
Make the valve springs a breeze too.
^^^ off topic, but what kind of cab lights do u have? LMC clears? Or dodge?
Is this thing done yet? oke:
-intercooler tubes
-un bolt master and abs and strap it to the motor.
-2 tranny cooler lines and ps cooler lines
-steering shaft
-hydro boost lines
-ground strap by heater box
-ground strap on right side by body mount
-both abs connectors by inner fender wells
-shift cable
-parking brake cable
-vacuum line on right fender well.
-connectors on drivers fender well.
-body bolts. 8 on a cc
-fan and shroud
-both radiator houses
-batteries and trays
-air box or intake
Oh well going fast in a heavy pig isn't easy.
