Turbo Options???
lsmith33
Katy, TX
i have any E99 and would like to upgrade..what are my options?? an unfortunetly money is a problem. jus lookin for a mild upgrade
CSIPSD
Bend, OR
lsmith33
Katy, TX
ok. would i still need to change mounts goin to the h2e or d66? or are they both direct drop ins??
CSIPSD
Bend, OR
D66 is a drop in... H2e has a complete mount kit...
Your money ahead to go with a T4 or T4i type in the long run.
SouthFlstrokin'
Well one out of three responders can read...
D-66 or a H2e type is your options... Unless you want to swap over to a L99 set up, and its not worth the cost to do that.
I would go with a T4 or T4i mount if it were me.
^THIS
Whytry
Memphis IN
Well I wasnt one of three that read anything lol but know that people have read for me d66 is my choice.
smokedout250
harrisburg oregon
Opps my bad didn't see the E..... d66 is your best inexpensive option... if you wanna do a mount kit call jake at irate or h2e is a good way to go but your up in the 2000s for those..
CSIPSD
Bend, OR
Correct, but your getting twice or more the mounting kit, plus a much better turbo set up...
Plus you can sell your old stuff and recoup about 1/3 of the cost.
CSIPSD
Bend, OR
ok thanks for the info......what are the rewards on swappin in a van turbo??
First you would have to find one that fit your E99 set up...
Other then that the 1.15 housing lowers drive pressures and boost levels a bit and cools the EGT's a little.
No HP gain or loss.
smokedout250
harrisburg oregon
And that right there is why my truck is going to irate this week! Not saying a d66 is a bad turbo but. There are better options available that's my 0.02
