ghohouston
you will need an oil cooler rebuild kit, it wouldnt hurt to replace intake manifold gaskets... would also be a good time to put new o rings on your turbo drainback tube, maybe pull your ipr while the turbo is off and have real easy access to it, and make sure theres no trash in the screen, and or that the screen is still attatched. and honestly, im not sure about the deltas, i just work on em when they come in rolling white coal. but like stated, if you park nose down hill and pull the mod valve, and the intake is wet, thats a tell tale sign your cooler has ruptured
