cknox121's slow build
Cknox121
Augusta GA
Truck- 2008 f-250 KingRanch 4x4 6.4l
Bought the truck with 110k on it from my cousin. He put sct on it around 12k miles with dpf delete.
So far I have
35% windshield tint
35 12.fidy 20 nitto mud grapplers
4in flow pro exhaust with 7in slash cut tip
Kenwood head unit- with switch to watch DVD going down the road.
Roll n Lock bed cover
B&W turn over hitch
Rigid LED light bar in front bumper
H&S Mini Max running 300 hd tuning
Here are some pictures of the truck:
Cknox121
Augusta GA
2 weeks ago I did a flo pro egr delete, polished intake elbow and CAC pipe. Also installed sinister coolant filter kit.
Egr install went pretty smooth, as well as sinister kit. I bought Corbin clamps because the crappy ones that come with kit leaked like a seal.
Now my next issue is that the truck puked coolant before egr delete. Thought that might fix my problem, but it didn't.
Notices some smoke from under hood. After further investigation, I found the source. Right across from the yellow blue red wires in this picture, there is some type of black gasket. Any ideas what this is? Oil is barely coming out and it's venting like my CCV does. Same color smoke.
This is drive side manifold FYI
Cknox121
Augusta GA
That's the injector harness I think. Pic is hard to see
I can't get a good picture of it with out removing fender liner.
See if I can get a better one later.
Can any damage occur from it leaking? It barely leaks.
Guess I hit it with the cooler when I was removing them.
Cknox121
Augusta GA
So from what I have read, puking coolant usually means head gasket/head bolt fail.
Is this correct?
B585Ford
WV
Is this correct?
IMO yep, that is usually the problem, especially on a '08. If you can get it to puke on a consistent pattern (like WOT and getting the boost to around 50), you could always run a pressure test off of the degas. A positive pressure test means the heads need to come off (checked for cracks and a new HG/studs).
webb06
Seneca, MO
Yes. And I would suspect that you might have just pulled the grommet out for the injector lead.
that would be the gloplug harness. not the injector harness. just push it back in so its fully seated. if its torn i would replace the harness.
hopefully the truck isnt puking on you...
Cknox121
Augusta GA
How long can I ride like this?? It's not drinking coolant, just puking when I give it hell. And I don't look at boost when I'm gettin on it lol, rather see where I'm going.
On another note, boost does build stupid fast since egr delete and new CAC pipe
Cknox121
Augusta GA
Thanks!
Oh she's puking. Coolant all over frame after a really hard run :(
Oh well. Be doing my head studs sooner then later.
Cknox121
Augusta GA
Here are some more pictures of the truck
-interior
Motor-
Clamps I used instead of the screw junk
Cknox121
Augusta GA
For the record, I don't have the camo steering wheel cover, and I replaced the mats with some weather techs
Cknox121
Augusta GA
Fixed my oil leaking issue. Had to take the damn fender liner out to get to it. Popped the little gasket back in. Guess it was glow plug harness.
Administrator
sweet.
Cknox121
Augusta GA
Opinions on a good fuel set up?
Worth it for stock injectors and turbos?
webb06
Seneca, MO
I wouldn't worry about it personally. Unless you going to add more fuel later. Only benefit to an airdog or the like for you now is a little better filtering setup.
Cknox121
Augusta GA
Thanks.
I read the fuel sticky but's it's all geared toward larger injectors, nothing stock.
Guess I will leave it alone for now...
B585Ford
WV
If you do the AD now, unless you do the CAT filter or something else similar, the filtration (down to 4 microns) isn't better than stock. Of course, the filter is a LOT easier to change. Unless you do the fuel bowl delete, you still have to get replace that one and you can't buy them separate last time I checked.
