SD Electric Fuel Pump Question
Tom S
With big injectors
Once nice thing about the Motorcraft pumps is they come with the mounting assembly short harness that I located a the maching plug for.
mjonesjr
Salem, IN
How big of injectors? Will 1 pump still work for stage 1's?
I am going to go get a SD pump off a wrecked truck this week and start collecting my parts for the conversion. I ordered the pre-filter and base and the post filter and base tonight from Fleet Filter. I also got a banjo block off eBay so I can retain my factory lines going into the heads with the factory banjo bolt that goes into the mechanical fuel pump.
Will the regulator need to be set at 60 PSI or 75 PSI?
Tom S
65 would be a good starting point. I cannot answer your question on size injectors that will work with one SD pump. Post up this block you are using for the fuel lines, I am curious to see it.
Arisley
Arlington, Texas
Compression fittings from Home Depot work well. A tubing bender from Harbor Freight is cheap.
http://www.harborfreight.com/tubing-bender-3755.html
Tom S
That is a good link for the guys that do not want to have to fab those lines. A couple of holes for mounting or a port for a pressure gauge would have been cool.
mjonesjr
Salem, IN
Yea that would make it even better.
I wonder if you could drill and tap that for 1/8" NPT to put in a gauge without any problems.
I was going to put a Tee fitting between the block and the hose fitting to put in a pressure switch to light the dash light.
mjonesjr
Salem, IN
I have been looking for a fuel pressure switch to put up in that region to trigger the lights.
You don't happen to know the part number of the one you used do you Tom?
What size is the fitting on the end of the factory return line as well?
Tom S
Sorry I get asked the question all the time and I just do not have the answer. I can tell I used an adjustable hobbs switch is all. I just adjusted it to get the pressure I wanted.
mjonesjr
Salem, IN
I figured you do.
Do you happen to know what thread size the fittings are on the factory return lines? I need to get an adapter to run into the Aeromotive regulator.
dave186
Idaho
I kinda like that block idea. didnt someone use some fittings from parker to do pretty much the same thing?
Tom S
It was TimC63 that did it with the parker fittings
If you look around the web there is a conversion chart to match wrench size to fitting size. If you cannot get to them on your rig I will check on mine.
mjonesjr
Salem, IN
I will look around.
It's no big deal. I just thought you might remember off the top of your head.
I was thinking I read somewhere that they were 1/8" NPT Female fittings.
Do you think it would hurt anything if I didn't run a fuel heater?
Tom S
I think they are -4 AN if you want to retain the factory return hoses but not sure.
