Check out our new injector boxes!
UNLIMITED_DIESEL
Bremen, Ohio
New injector packaging coming soon!!! Most injectors should be in stock by the end of next week!
UNLIMITED_DIESEL
Bremen, Ohio
All cores should be returned in these boxes unless cores are being sent in prior to sending your injectors out.
We will not be accepting any cores that are not properly packaged. This will be clearly stated on our website tomorrow.
We will absolutely refuse any injectors that are shipped via USPS flat rate boxes. No matter how well they are packaged, the solenoids always get damaged.
Thanks!
ToMang07
Mainah!
So if someone want's to send their cores in ahead of time you're just going to ship them an empty box first?
UNLIMITED_DIESEL
Bremen, Ohio
We can do that at the customers expense, or just make sure that they are packaged well enough to not be damaged. Also, do not ship them through the USPS. Anyone using common sense can tell the difference between packaging so that there is no movement and plenty of cushion, and just throwing some injectors in a box and taping the box shut.
