20x12 -44 with 305/45?? no lift??
oneton
fla
And this is what it looks like now:D SD axles and 20x12 -44 305/50/20s Toyo ST II
looks good.when i wear these 37's out,i'm gonna lower mine down like that
oneton
fla
What offset and back spacing do you have?
no clue bought them from another guy
I do have a 4" lift alos but you can see how wide the 20x12s
the armours are only offered one way in offset and backspace.almost the same specs as op's wheel.
tire width may be the diff,as to why they scrub.my 12's with same specs dont scrub.a friends truck has 22x14's and his dont scrub.only tires i've had scrub was 36x11 on stock alcoas
not enoughsmoke
lynnville tn
they only rub the driver side spring i think it might be a tie rod adjusment issue my tires are 15.50 wide
kanuck15
Grampian PA / West Palm Beach FL
old thread revival
But how do you like this setup? I have SD axles and am about to put 305/50R20 nitto 420s on it. My wheels are 20x8 factory SD 20s so I wont be as wide but are you running wheel spacers? I got 2 inch spacers all around for mine to try and get a little stance out of it
96F350KID
Nokomis FL
Looks awesome, have more pictures on the company Facebook page if you're interested. Most your issue is wheel spacers only add backspace they don't change offset so you may rub a small bit. If the M/T sportsman 32x18x20 tires weren't $400ea id stick those on it. Im gonna try 305/55 next time around but i really like these. No rubbing but had to trim the bumper.
oneton
fla
can you post pics here?i dont do the facebook thing.
smcox1
You're so late to the party the party has come and gone three times. You're almost 3 years late buddy LOL LOL
