BFH turbo
pontiacross
I have a 80/88 BFH turbo sale. for those that don't know this is a s400 turbo with a H2e exhaust housing so it will fit on the hypermax mounting kit. turbo also comes with a 66mm compressor housing to make it legal for 2.6 pulling class. $900 OBO
pontiacross
yes it is non protrusion, I had a protrusion wheel and cover but already sold that
pontiacross
the turbo is out at our shop, I'll try to figure out what size it is when I'm out there this weekend
pontiacross
All of the numbers have been ground off the housings so I am not sure exactly what size they are. but I do know we put a little tighter exhaust housing on then they normally run to keep it spooled with the 2.6 housing on. but I ran a boost and drive pressure gauge and even with the 80mm cover on drive pressure was pretty close to boost, maybe 10psi over at peak
pontiacross
pontiacross
I don't think it would be too bad with those injectors but I can't guarantee it because I always ran bigger ones with it
the tighter exhaust housing helps, but its not a low rpm turbo for any set of injectors.
How far down could you lug the lone stroke before snuffing it out?
pontiacross
I don't think I ever snuffed it out with this set up if everything was working right, but I ran 3500 to 4000 rpms down the track and it might pull down to 3000 at the end. I did break a rocker arm or 2 and it would snuff it out if I was running on 7 cylinders but that's a different story LOL
Holy chit! Thats also with extensive porting and cam right?
7 cylinders my hinder it a bit lol..
pontiacross
stock heads, stock cam, stock rockers, smith brothers push rods, comp 910 valve springs shimmed (had to had a few more shims when I started breaking rockers) and stock bottom end.
it took about 3 days on an engine dyno at swamps to make it happy at 4k
a little hard to read but peak power was at 4100 rpm I had runs with more power but this was the best over all power and rpm. power was probably down a little because it was 20+_ runs into the day. If I remember right john was letting out at 2400 rpm to save the bottom end and it was still on top of the turbo there
Holy ***in sh!t!!!!! I thought all that was with porting and cam. Dam thats amazing! How much of a improvement would it have been with port and cam work?
