Wildcat
Anybody running 22's on a stock or leveled truck? Need to know what offset to run. Would like to stick with a 285/55/22 Nitto which is close to a 34x12 on stock suspension. Going on a white 15 platinum.
Thanks. i have to run mud flaps or my paint will look like sheeet in a month.
Fox....Your truck? Thats the Burnout right?
Get a 22x10 or 22x11 if you plan on staying stock height.
22x11 If you want no rubbing or trimming.
22x10 if you don't mind some rubbing and trimming.
The 11 wide will have "like stock" appearance as far as sticking outside the fender well.
The lip on a 10 wide is larger than an 11 wide contrary to common thinking.
A 12 will not clear without a minimum 2.5 and heavy trimming
22x10 clear with a 35/12.50 on a leveled truck?
Correct. We put them on a 13 platinum with an icon 2.5. Actually running a 325/50/22. Very minimal trimming.
These are 22x11 with 0 offset and 35x12.50x22 Toyo M/T's with 2.5" leveling kit.
I've got the 22/10 rebels with a set of 285/55/22 terra grapplers waiting for my '15 to show up this week. I do not plan on leveling it either. We will see..
