Pics of AF 22's?
Wildcat
Muskogee, OK
Anybody running 22's on a stock or leveled truck? Need to know what offset to run. Would like to stick with a 285/55/22 Nitto which is close to a 34x12 on stock suspension. Going on a white 15 platinum.
smokinstroker
Texas
Get a 22x10 or 22x11 if you plan on staying stock height.
22x11 If you want no rubbing or trimming.
22x10 if you don't mind some rubbing and trimming.
The 11 wide will have "like stock" appearance as far as sticking outside the fender well.
The lip on a 10 wide is larger than an 11 wide contrary to common thinking.
A 12 will not clear without a minimum 2.5 and heavy trimming
Swampfox
TN
These are 22x11 with 0 offset and 35x12.50x22 Toyo M/T's with 2.5" leveling kit.
Wildcat
Muskogee, OK
Thanks. i have to run mud flaps or my paint will look like sheeet in a month.
Fox....Your truck? Thats the Burnout right?
ClayStewart
Weatherford, TX
I can't get pics to upload for some reason. But I am running 22x12 octanes with 325/50/22 and 2.5 level kit. No rubbing whatsoever. That being said, I did have to trim the fog light bracket on the bumper as well as some of the inside lip of the fender and pinch weld. Nothing you would notice without taking a real good look at.
jdgleason
Fort Collins, CO
22x10 clear with a 35/12.50 on a leveled truck?
Wildcat
Muskogee, OK
I've got the 22/10 rebels with a set of 285/55/22 terra grapplers waiting for my '15 to show up this week. I do not plan on leveling it either. We will see..
Thats what Im talking about. Im running the same tire on my 12 right now that is stock height with no rubbing. The thing I like about the tires is they are 80 psi tires.
