04 250 clunk on take off
nasty6.6
San Angelo, TX
I have a clunk on take offs, immediately after letting off the brake and getting going. I think it has something to do with the slip yoke on the rear drive shaft. Does anyone know what to put on this to help? U joints are all tight as well.
Thanks in advance.
HOOV3R
Central PA
Is there any play in the yoke when spinning it? You can pull it apart and inspect it, if the blue nylon coating is coming off it will need repaired.
Trqmnstr
VT
Grease the yoke and output shaft.
Probly will need to pull the drive shaft to grease the yoke good, i havent looked yet but i have the same clunk and need to fix it.
drunk on diesel
sometimes you can just unbolt from the rear diff, slide the driveshaft in and out a couple times and bolt it back up, and it'll spread the grease in the slip yoke around
nasty6.6
San Angelo, TX
thanks for the info I will try this weekend and let you know what works!
Driving the truck today I had a loss of power and lots of white smoke so it looks like I have a weekend full of time with the truck... I hadnt deleted yet so looks like i will be doing that as well
