08-10 6.4l twin turbo or single
CockDiesel
Hi all,
I have a 2008 f250 6.4l manual transmition with 7 in lift and 37x13.50 tires with a *******n tuner running at 250 hp , egr full d******d exhaust and a south bend double clutch. One of my turbos went on my truck and was thinking about going to a single turbo.
It's my daily driver and I never pull a trailer . Would it be better to get a single or upgrade on a new twin
NY_Mott
The Real "OC" NY
I'd say stay "Compounds" for ease of driving & cheaper at your current setup.
Unless your trying to go all out or just really want a single.
Sent from my SM-N920V using Tapatalk
CockDiesel
I was looking at running a single 73mm from H&S mainly for more reliability and less moving parts .. If I do run the compound what size setup?
6.4 Stroker
Rapid City South Dakota
Given your setup, I'd recommend an upgraded atmo 72mm turbo.
By far the most bang for your buck, and would make 650hp+ spooling effortlessly.
A single with a big lift and manual trans isn't the most ideal for spooling, but can be done.
If you have your heart set on a single. I would think about a turbo in the 66mm range. That would aid spooling for stock fuel.
