1000 RWHP Build for the summer
ingrahams
New Hampshire/Africa
couldnt tell you what was going on with the first few runs, boost was about 10 psi lower than the street until he turned the load up on the final run. still frustrated that the nitrous express solenoid was faulty right out of the box, works fine until it gets tank pressure on it then it wont open unless you smack it with a wrench.
-Stew
bigrpowr
<How I Fly
Administrator
Yep I've had that problem before. It's usuallu from high bottle pressure. Congrats buddy.
ingrahams
I don't have a gauge on the bottle, might work now after I let a guy with a 6.0 excursion borrow the bottle for the dyno, ended up coming in second with 811HP.
ingrahams
Well finally got to the track, ran a best of 11.45 @ 126. Was launching soft to get a feel for it so the 60' were in the 1.7-1.8 range. Tried launching at 20 psi but it hopped bad so I had to get out of it. Nitrous bottle was only at 700 psi and I don't have a heater, it was puking coolant out of the reservoir, and I didn't take Mikes advice on dropping the tire pressure down to 32. Next time I'm going prepared and shooting for 10's.
alradco
That is a ton of mph, truck is making serious power.
Peter
nick01
BONER
Edit: Watched video several times, still not old. Sounds like a jet!
bigrpowr
<How I Fly
Administrator
congrats buddy !!! yeah i believe your 60ft's should be high 1.5 really low 1.6 once you get that figured out .. 10.xx !!
