2.5" Icon lift, 20x10 American Force wheels. What size tires?
UNLIMITED_DIESEL
Bremen, Ohio
Looking at getting a set of Toyo M/T's, trying to decide what size.
2008 F-250 4x4, 2.5" Icon Lift kit with OUO ALA's, 5" OUO traction block rear.
20x10 American Force Rebel SS8 wheels with -25mm offset.
Can I clear 35's? Or am I going to be trimming a lot to get it to work? Anyone with similar setup, pictures would be greatly appreciated!
35x12.5x20 will work. if you have factory flares they will rub if you are on uneven ground.
RedRice589
Ocala, Florida
I had icon 2.5" with 325/65/18 -24 offset and it didn't rub. Had BFG a/t's and then cooper discoverers. Only if I really flexed it turning would I hear a small bit and that is if I slammed something hard.
Jeff@Spartan
Georgia
I ran 20x10 BMF's with -19mm offset and 35/12.50 Toyo MT's at stock height with very minimal rubbing on my 08. They cleared with zero rubbing when I did a 2.5"
ICON setup.
WHY NOT
Carlyle IL
You can clear 35s with that set up maybe some minor trimming that's what I had to do to mine. Here is my 11 with the same suspension minus the ALAs and 35x13.50: on 10 wides
Sent from my I fone 5
smokinstroker
Texas
You'll be able to clear it but you will need to trim some of the inner fender and possibly space the bumper out. The 35 toyo seems to clear pretty well with a 2.5 and 20x10 american forces.
UNLIMITED_DIESEL
Bremen, Ohio
Thanks! This is exactly what I was looking for! I will be buying 35" Toyo's for sure now! Even if I have to space the bumper out slightly it won't be bad.
Do you happen to have a picture from the front or rear of the truck? Id like to see how far the tires stick out.
Thanks again guys, much appreciated!
RedRice589
Ocala, Florida
Yes my fender liners were trimmed and tied back with big zip ties!
WHY NOT
Carlyle IL
Hope those help.
RedRice589
Ocala, Florida
These are 325/65's were 34.8 and 12.8 wide on 18's -12 offset though.
These are cooper discoverer didnt't rub with either set.
skevac
Michigan
That is one damn nice looking truck!!!! Glad to see that someone still likes a nice set of chrome wheels! What back spacing and offset are those? Does the Icon 2.5" kit make the truck sit any higher than a 2.5" leveling kit on an
F350? Thanks
WHY NOT
Carlyle IL
F350? Thanks
-25mm offset so i think that's 4.5" bs. The icon kit should be pretty much the same as other 2.5 kits.
