Twinturbostroker
El Paso, Tx
Odd one for you boys......
2010 F250, I can give the vin if you need the exact interior color but I believe its called medium stone, its not the light tan and its not the work truck grey, but I need the driver side pillar cover and handle, or maybe just the handle, if thats possible
Then I need a fuel banjo bolt for the fuel line going to the fuel cooler and the I need a oil banjo bolt going the passenger side turbo...please!!!
trying to remove some God awful pillar gauges that came on the truck, thanks!!!
sunrisefordparts
i believe the handle is with the pillar bezel
list $109.83 sell $79.08
banjo bolts list $7.43 each sell $4.46
washers list $4.78 each sell $2.87 each
free shipping
q#358939
Sahrens0202
OH,WY,ND,CO
6.4l intake manifold gasket
6.4l exhaust manifold gasket
6.0l exhaust manifold bolts and spacers(putting 6.0l manifolds on 6.4l)
dana 60 axle dust seals
dana 60 inner axle seals
shim/bearing for installing a TruTrac in a dana 80
All this is for a 2008 F-350 cclb dually King Ranch
sunrisefordparts
intake gaskets list $15.09 each sell $11.77 each
exhaust gaskets list $15.03 each sell $11.72 each
bolts list $1.59 each sell $0.96 each x16
spacers list $1.60 each sell $0.96 each x16
on the seals are you looking for the inner at the diff or by inner do you mean just inside of the knuckle?
as for the rear you would prob only need the bearing and race for the carrier and shimming wouldnt be known till your install.
q#359308
Cppr Busa
Illinois
Master cylinder, hydro booster and rubber brake lines for the rear(driver, passenger and middle line)
For a 2002 F-350 cc lb 7.3 4x4
sunrisefordparts
master list $224.23 sell $161.45
booster list $516.48 sell $371.87
lh tube list $70.23 sell $50.57
rh tube list $76.82 sell $55.31
center tube list $59.50 sell $42.84
free shipping
q#359751
