Sahrens0202
OH,WY,ND,CO
intake gaskets list $15.09 each sell $11.77 each
exhaust gaskets list $15.03 each sell $11.72 each
bolts list $1.59 each sell $0.96 each x16
spacers list $1.60 each sell $0.96 each x16
on the seals are you looking for the inner at the diff or by inner do you mean just inside of the knuckle?
as for the rear you would prob only need the bearing and race for the carrier and shimming wouldnt be known till your install.
q#359308
Inner by the diff, I am putting a dynatrac free spin on. Also the dust seal which is just on the diff side of the ujoints. Also, do you have the greasable Spicer ujoints for it? Can you put it all on one quote? Sounds good on the bearing and races.
sunrisefordparts
ok well the only thing that will change on that quote is those inner seals, list $54.28 each sell $39.08 each, as for the ujoint the ford ones aren't greasable so prob through napa you could get the greasable ones.
thenephilm
Cincinnati, OH
I have a 2008 f350 4x4 standard cab XL with a 5.4. I need the following parts:
Master Cylinder 8C3Z-2140-DB
Lower Weatherstripping Piece F81Z-2520758-AA
Gas Filler Pipe 8C3Z-9034-KF
Upfitter switches and harness
Foglight Switch and harness 8C3Z-15A211-A & 8C3Z-11654-CA
Thank you for your help.
sunrisefordparts
master list $346.40 sell $249.41
weatherstrip list $28.77 sell $20.71
filler neck list $280.72 sell $158.33
upfitter switches list $170.52 sell $102.31
harness list $137.47 sell $98.98
fog lamp wire list $45.87 sell $33.02
switch list $59.40 sell $39.20
on the filler neck it shows the part number being listed for a 6.4 diesel, and on the head light switch thats for w/fog lamp and w/auto lamps.
q#360063
Twinturbostroker
El Paso, Tx
Odd one for you boys......
2010 F250, I can give the vin if you need the exact interior color but I believe its called medium stone, its not the light tan and its not the work truck grey, but I need the driver side pillar cover and handle, or maybe just the handle, if thats possible
Then I need a fuel banjo bolt for the fuel line going to the fuel cooler and the I need a oil banjo bolt going the passenger side turbo...please!!!
trying to remove some God awful pillar gauges that came on the truck, thanks!!!
Got my parts, thanks fellas.....but small issue, the driver pillar cover didn't come with the two small covers that hide the mounting bolts.....is that something else I need to order?
sunrisefordparts
sorry didnt think you would have needed those since you had a moulding there i just figure they were still in tact. those little covers run you $4.97 each and i have 2 on the shelf.
Oh-ate6.4PSD
Vicksburg,MS
just wanna be clear, its the lines that dont use the external filter under the bell housing rite? And i wanna add a filter #ft180 and a pan # 8C3Z7A194B
sunrisefordparts
that is the lines without filter, i priced both the line at the cooler and the lines from the quick connect at the cooler line into the trans fittings.
ft180 list $77.69 sell $41.95
8c3z7a194b list $88.43 sell $63.67
