weareweird69
Blairsville, PA
1 - F4TZ-8200-A: List $167.07 -- sell $110.26
1 - F2TZ-13064-D: List $41.82 -- sell $28.85
1 - F2TZ-13064-C: List $47.53 -- sell $32.80
2 - F2TZ-9925622-AP: List $32.98 -- sell $22.00 each
2 - F1TZ-13550-A: List $11.82 -- sell $8.15 each
+ shipping
thanks,
Sean
Quote#571340
Old quote, curious on price increases.... Including the shipping cost to 15717 or 15701. The grille might be better bought local due to size, but never know.
sunrisefordparts
Hi,
Looks like everything changed...
1 - F4TZ-8200-A: $165.56
1 - F2TZ-13064-D: $25.89
1 - F2TZ-13064-C: $26.29
2 - F2TZ-9925622-AP: $24.29 each (currently on backorder / no ETA)
2 - F1TZ-13550-A: $11.59 each
1 - F4TZ-15044D70-C $119.50
shipping is coming up at $53.22 for everything...
thanks,
Sean
weareweird69
Blairsville, PA
Hi,
thanks,
Sean
Sean,
Get me everything except the decals unless the black variation of that decal is available. And add another dash bezel.
Pm me the whole quote please and I’ll get you paid.
rescuejg
Can you quote the following for pickup at Noho location:
E7TZ-4B409-A Tone Ring
2C3Z-4865-BA Flange
5C3Z-3A093-AA Track Bar Bracket
C3Z-5415-AA Coil Spring isolator (quantity 2)
W715479-S439 Lower shaft bolt
W714409-S439 Lower shaft upper bolt
N803942-S102 Lower shaft lower bolt
W720370-S900 Spring Front Bolt (quantity 2)
W717083-S442 Spring Nut (quantity 2)
W714456-S439 Spring rear bolt (quantity 2)
N620485-S441 Spring Nut (quantity 2)
HC3Z-5705-E UBolt (quantity 4)
BC3Z-5796-E Mount plate (quantity 2)
Thank you
sdh1994
2010 Hydroboost
I am looking for a price for a hydroboost and master cylinder for a 2010 f350 6.4, I also need rear spring blocks, I don't have factory ones anymore so unsure of size. I can provide you vin if needed. Thanks
sunrisefordparts
Hi,
Can I get the last 8 digits of the vin just to be sure
thanks,
Sean
sunrisefordparts
hydroboost: List $537.05 -- your price is $324.92
master cylinder: List $237.51 -- your price is $143.69
rear spring blocks: List $58.37 -- your price is $38.52 each
+ shipping
(the hydrobooster has a gas in it that is considered hazardous material so there will be a $25 hazardous material shipping surcharge)
Q643806
thanks,
Sean
sunrisefordparts
2C3Z-4865-BA Flange
Thank you
E7TZ-4B409-A Tone Ring $48.36
2C3Z-4865-BA Flange $45.66
5C3Z-3A093-AA Track Bar Bracket $103.95
5C3Z-5415-AA Coil Spring isolator (quantity 2) $18.26 each
W715479-S439 Lower shaft bolt $1.38
W714409-S439 Lower shaft upper bolt $1.38
N803942-S102 Lower shaft lower bolt $3.30
W720370-S900 Spring Front Bolt (quantity 2) $7.43 each
W717083-S442 Spring Nut (quantity 2) $7.43 each
W714456-S439 Spring rear bolt (quantity 2) $3.58 each
N620485-S441 Spring Nut (quantity 2) $1.38 each
HC3Z-5705-E UBolt (quantity 4) $19.91 each **ON BACKORDER THROUGH END OF MARCH**
BC3Z-5796-E Mount plate (quantity 2) $42.50 each
Grand total after tax = $479.30
Q643600
thanks,
Sean
under construction
Jamestown, OH
2016 f450
9c3z-17906-cptm rear bumper with sensors
Bc3z-17757-cptm front bumper (not sure if this is right) I need to one with the holes to mount the flares.
Bc3z-8200-bptm grille surround
7c3z-17d743-a mirror cover
7c3z-17d742-a mirror cover
rescuejg
Shout out to Sean and the parts guys at Sunrise. I placed a couple orders recently. Very quick service. Excellent communication. They found the correct part numbers I needed. I am converting to coil springs, so looking up parts wasn't as simple as entering a VIN. Their pricing appears to be as good if not better than the other OEM Ford online retailers. I will definitely order OEM parts from them in the future.
sunrisefordparts
2016 f450
9c3z-17906-cptm $560.06
Bc3z-17757-FPTM $749.55
Bc3z-8200-bptm $212.94
7c3z-17d743-a $70.91
7c3z-17d742-a $68.06
+shipping
due to the size / weight of the bumpers shipping is going to be outrageous...
thanks,
Sean
q646117
08REDSLED
Linwood, KS
Need a 3 bar MAP for 2015 explorer p/n AA5Z-9F479-D - i do know this is not the stock sensor, also a tail housing gasket for an 08 F450 4x4 5R110W
Thanks!
trevdalocal
Honolulu, HI
Hey Sean,
Looking for the following for a 1996 F350 XLT Crew Cab SRW 4x4:
-Push clips to retain all four interior door panels (Believe its 28x N802900-S)
-All screws to attach all four interior door panels (5 on botton of each front door, 1 at top of each front door, maybe same as bottom screws, 3 on bottom each rear door, 1 per door in the door "handle" cup, total 22 screws)
-Both rear wheel cylinders
Shipping to Waianae, HI 96792
Thanks
Trevor
