sunrisefordparts
Need a 3 bar MAP for 2015 explorer p/n AA5Z-9F479-D - i do know this is not the stock sensor, also a tail housing gasket for an 08 F450 4x4 5R110W
Thanks!
MAP: $87.12 ($144.00 retail)
tail housing gasket: $7.32 ($11.08 retail)
+ shipping
thanks,
Sean
q646595
sunrisefordparts
Hey Sean,
Looking for the following for a 1996 F350 XLT Crew Cab SRW 4x4:
-Push clips to retain all four interior door panels (Believe its 28x N802900-S)
-All screws to attach all four interior door panels (5 on botton of each front door, 1 at top of each front door, maybe same as bottom screws, 3 on bottom each rear door, 1 per door in the door "handle" cup, total 22 screws)
-Both rear wheel cylinders
Shipping to Waianae, HI 96792
Thanks
Trevor
Push clips: N802900-S $.33 each
5 screws on botton of each front door: N805123-S58 (no longer serviced)
1 at top of each front door: N806578-S58 (no longer serviced)
3 on bottom each rear door: not listed in illustration
1 per door in the door "handle" cup: 56914-S58 (no longer serviced)
sorry,
Sean
trevdalocal
Honolulu, HI
sorry,
Sean
Sean, are the rear brake cylinders still available?
I'll take the 28 clips if they're available, if the shipping isn't crazy. Should be able to fit in a little flat rate box?
sunrisefordparts
Yep, they should be fairly cheap to ship even to Hawaii... Just PM me your email address again and I will send you the quote.
thanks,
Sean
08REDSLED
Linwood, KS
What would a set of front locking hubs for an 04 F350, the hubs say auto on them, but the truck never had auto hubs, they were always manual
Thanks!
sunrisefordparts
Thanks!
Weird, according to the picture in the catalog it should say " FREE and LOCK"
Your cost is $106.94 each ($162.03 retail)
we do have one in stock, but the second one would be backordered through at least 4/22...
sunrisefordparts
sunrisefordparts
Need price for 2002 7.3 oil cooler, orings and gaskets.
Hi,
Cooler body: $210.86 ($319.48 retail)
oil filter end: $268.90 ($543.22 retail) currently on backorder
timing cover end: $86.26 ($174.27 retail)
2 orings: $9.24 each ($12.92 retail)
2 orings: $4.07 each ($5.69 retail)
end gasket: $15.07 ($21.08 retail)
end gasket: $22.74 ($31.80 retail)
total: $630.45 + shipping (and tax if applicable)
thanks, Sean
Q648542
