sunrisefordparts
bowsniper
HC3Z-14C022-B is the bracket they used '18-19 see attached pic.... LC3Z-14C022-C is a new part number showing '20-21, I am fairy sure it is the correct one...
Sean, sorry to beat this to death, but the attached picture from the Ford service manual shows part I'm looking for, and the manual refers to it as "CCM base bracket". Is it possible that this part should have been included with PN LB5Z-9E731AB?
Thanks,
Mark
sunrisefordparts
Thanks,
Mark
No, there is a note in the catalog for the CCM that states "Less Bracket"
bowsniper
Sean, Could you possibly direct me somewhere up in the Ford parts or engineering divisions where I could get a part number for this mounting racket? I can't be the first one that needs this part. Any significant front end repair to a ACC equipped truck would also need this small plastic mounting bracket for the speed sensor (cruise control module).
Thanks,
Mark
sunrisefordparts
Thanks,
Mark
Unfortunately the only means we have to contact them is electronically. I have created a case, it may take a day or so before I hear back...
sunrisefordparts
Thanks,
Mark
Hey Mark,
Ford cataloging confirmed that it is: LC3Z-14C022-C, it will work in conjunction with the LC3Z-14C022-A you already purchased...
thanks,
Sean
bowsniper
Thanks Sean, Do you have a LC3Z-14C022-C in stock that you could visually check before you ship? I am a little suspicious because the small plastic plate MSRP is $92.90, more than the cost of the steel mounting bracket LC3Z-14C022-A.
Thanks,
Mark
sunrisefordparts
Thanks,
Mark
No, unfortunately we do not stock it, and I can't find a illustration or pic of it anywhere... If you want to order it, I can check it before it ships...
97cherokee
hello i need a price on
3C3Z-8326-AA radiator wind deflector for 01 f250
brmc27 brake booster for an 01 7.3
and the master cylinder for a 2001 f250 7.3 with cruise control
shipped too 30189
thanks
sunrisefordparts
shipped too 30189
thanks
Hi,
3C3Z-8326-AA: $201.17 ($304.80 retail)
brmc27 is actually the master cylinder: $92.76 ($153.33 retail)
booster: $258.06 ($426.55 retail)
The hydrobooster would have to be shipped as "hazardous material" because it contains a gas that is considered hazardous material, so shipping is coming up at $135.64 for all three parts.....
without the booster shipping is coming up at $76.80, (probably because of the size of the deflector)
thanks,
Sean
q653995
bowsniper
Hi Sean,
I need the front edge plastic trim piece on the passenger side running board. The PN might read FL34-16N452-C, but is not very readable. I do not see this PN on your website. My VIN is 1FT8W3BN2LED24876. Thanks!
