Countryboy07
N. Manchester, IN
2003 6.0 Powerstroke:
-Complete set of valve cover bolts for the drivers side valve cover
-Turbo oil feed line gasket
-Turbo oil drain line o-rings
-9T288 HPOP discharge line and or O-ring where it connects to the branch tubes
Countryboy07
N. Manchester, IN
Taylor D
Sebring, Florida
2001 E450 7.3 psd drw 2wd front coil springs and do they offer a heavier spring possibly 550 coil springs
Sent from my LG-LS980 using Tapatalk
ford_trck
Vail, AZ
2008 Rear differential cover and bolts
99 F-250 2 wheel drive
transmission mount
the 3 jack tools that are under the hood
metal cover for the torque convertor
racerdad2
95 xlt 7.3t eclb 2wd 5sp AC engine bottom gasket set, water pump, thermostsat, thermostat housing, alternator & ( voltage regulator ? ) sepentine belt, idler pulleys, coolant catch can & 16psi cap, oil cap for valve cover. Thx!
Sent from my SPH-L710 using Tapatalk
sunrisefordparts
bolts list $4.19 each sell $2.51 each
oil feed gasket list $6.86 sell $5.35
drain tube orings list $7.42 each sell $4.45
9t288 line list $145.10 sell $104.47 (doesnt show the orings seperate from tube)
free shipping
q#320086
sunrisefordparts
08 F250
Hydraboost system.
5qt of power steering fluid.
Cory Anderson
booster list $438.65 sell $315.83
master list $358.15 sell $257.87 (need to know if you have intergrated tbc or not, this master is with and is highest price)
fluid list $6.98 each sell $5.75 each
shipping $10
q#320091
sunrisefordparts
there is quite a few spring codes for that year, if you can get me a vin or current spring code i can see what i can dig up.
sunrisefordparts
on the alternator and the belt i need to know what alt you have, if its a motorcraft, leece neville, or mitsubishi?
