2006 6.0 Project Truck
aroache
Hanson, MA
My 2006 F250 project truck is for sale. Need to move this quick. Truck does not run and had low pressure oil issue. Have not torn it apart but mechanics said lpop/front cover needs to be replaced.
Truck is an 06 with 148,000 CCSB with 2015 bed. Very clean inside and out. No rot, small surface rust underneath. Frame is perfect with new coil buckets up front. Lariat interior
Motor is an 07 block bore 30 over. Elite diesel coated delipped pistons. Balanced and polished crank, new oem rods, arp hardware throughout. Studded with new heads, hd lifters, valve springs, rcd pushrods. Warren 175/75 injectors, stage 2 camshaft. BPD water pump, oil cooler ****** plate
Whole motor only has a few days worth of run time on it.
Truck needs a handful of parts to be finished:
Hpop
Fuel set up
Turbo
Degas
Intercooler
Ic pipes
Intake
Other misc. stuff
$6500 obo
Pm for more details
Sent from my SM-G955U using Tapatalk
