2008 F350 lifted KR Dually
JuststrokeIT
mainly looking to sell how it is Ive thought about taking it back to stock and trading it in and just selling the lift,wheels and tires But I dont know
TurboM700
Minnesota
What do you mean? I guess I dont get what your saying I cant see any rotors?
Whats all the alum flake on the rotor. Or what am I seeing in this picture.
O2ShootTheJ
tried to get my dad intersted in this but its just too big. He wants something he can pull a 5th wheel with.
JuststrokeIT
Yes that would be paint chipping off the wheel balancers not the rotors. Its got centramatic wheel balancers
N8theGr8
Keller texas
Have a 2008 Harley f250 lifted on 38s. Full delete with Elite wastegate injectors studded, spartan with dash daq built trans ect ect with 76k on it. Willing to trade strait across
JuststrokeIT
Bump truck now has 91,000 on it 9,000 mi ago it got 2 new heads due to cracks in the valve guides got brand new heads from ford had the machine shop chamffer all the sharp edges on the head to hopefully avoid cracks from ever starting on these new heads it got new ford OEM gaskets and ARP studs while I was in there I replaced all the lifters and the oil cooler and High pressure pump gasket just for peice of mind. I also put on new 6.0 ported exhaust manifold and rudys coated custom up pipes with wastegate port I still have my wastegate but never got around to putting it back on but it can be installed at any time, also has RCD ported intake manifold and a new pro 5R air filter and 2 new front tires as the truck wasnt properly aligned and was wearing the outter edges of the front tires funny the truck got realigned at this time also so it should be good to go, its got new brakes and rotors and wheel bearings and seals from national in the rear as well I figured since it needed new rotors and I was in there I might as well replace everything associated with it and all new u-joints in the back drive shaft had a bad one at the rear axle but while it was out I figured I might as well just throw all new ones in and be done with it. I do think that it needs a new carrier bearing as its got some play to it but I havent had time to adress that yet. Also the sunroof started to leak a few weeks ago in all this heavy rain weve been having so when I get some time from work and planting Im going to have to pull the headliner and figure out if the drains are plugged or whats up with it
JuststrokeIT
Bump tried to get a few pics the other day and tried to include any of the scratches and the dent in the tailgate as well
